Help Drop Box
shortride
When I open the Gallery on my Mesmerize there are 2 groups of photo's. One holds all of the photo's that I have loaded onto my phone. There is one photo that is also in the other group but it is by itself in something called "Drop Box". Will someone explan this to me?
Unfortunately I don't have an instruction manual. It accidently got thrown out with the original box into the trash.
Maybe this is an automated sync from DropBox (if you have the app) you could check it. I'm not sure though
I don't have any other amp on my phone other than the ones that came on it. I watched the Dopbox video and I'm not sure if that can explain why the one photo is by itself in my Gallery on the Mesmerize.
What do you remember about that photo? Did you take it with a 3rd party app? Did you download it from an email or text message?
The Dropbox app does not automatically put items into its folder, you have to designate them to be there. If you don't even have the app loaded on your phone, my guess is that the photo wound up in the folder because of a third party app.
I put all of the photo's on my phone the same way. I plugged my phone into my desktop computer with the USB cable, pulled down the USB connection option, checked it to be "MOUNTED". After the folder shows up on my desktop I found all of the photos that I wanted to drag and drop into the 'SAVED PICTURE" folder on the Mesmerize. That is the only way I know to load photo's onto my phone.
Is there something I could have done after all of the photo's got loaded onto my phone that could cause only the one photo to get into the "Drop Box"? I can't find a file or folder on my phone labeled, "Drop Box".
