Help Drop Down/Pull Down Menu Issue with Power Amp Music Player Control Buttons After Lollipop Update
Brianm109
Member
I use Power Amp as my music player and before the Lollipop update when I was playing music and I pulled down the notification screen I had controls that would allow me to pause, skip stop and etc my music. However after Lollipop I can't see the buttons anymore becasue they are white. Anyway to change the color?
You are 100% correct!! I have looked around for a way to change the LP theme and I do NOT know of any.
I'll follow this thread so I might learn also.
Lateck,
Lateck,
Lateck,
I figured out it out. Follow these steps;
1. Open Power Amp app.
2. Go to its Settings
3. Go to Look and Feel
4. Go to Status Bar/Notification
5. Check the Inverse Notification Colors box.
Hope this helps
Lateck,
Hope this helps
Thank you. It works....
Lateck,
Lateck,
it comes back after you skip next track..only thing i liked poweramp was the sound..otherwise its a shit app, developer is lazy ass who doesn't know what he is doing, people paid for working app now this shit keeps breaking on each android version update
