I was very excited to get my Evo V 4G.. I told myself to treat it extra special so it can least awhile. The very first day I had it, I got out of my car at work at night, it was on my lap, it fell on the pavement. Wow, I was really mad. I'm not as mad now.. since this still is an awesome phone compared to my Triumph.
The bottom left corner/bezel around the home screen.. The aluminum piece bent out a little. I can't bend it back while the phone is put together. I can deal with that.. When I'm on the phone, the ear speaker is very low. It worked great when I first used it. I have messed with the software and also I'm running angry bean. It definitely is a hardware failure. If I didn't damage the bezel.. I would return the phone or call VM for a warrenty fix.
Has anyone taken apart their Evo V's? I used to take apart intercepts and actually had this same problem before. The ear speaker was detachable and the metal contacts were loose. When I pressed them tighter together, the sound worked better. I'm wondering how hard it is to take this one apart.. If it was worth messing with. I am using speakerphone or a bluetooth earpiece for calls, kind of annoying.. But I still love the phone performance.
