Dual clocks
Hi,
Thanks for your replay,
I didnot download any widget on the phon, and regarding to the clock i have to say that everything is default
Thanks
Yes I know you are using thw default dual clock widget, and no, you cant remove one and keep the other. If you want only one clock on your homescreen, use a different clock widget.
Upvote 0
Just long press on the clock and drag it to the trash bin. Then get another clock widget that shows only one clock. Don't think about it. You can always get it back on your screen if you want. Its not default. What I mean by default is that, its part of the Touchwiz default set of widgets, widgets that come default with the phone and cannot be uninstalled. I probably should have said "stock", not "default".
My friend's S3 defaulted to another clock widget, not the dual clock, when it was newly opened. I have no idea why yours did. We have 3 Samsung devices at home and non of them had dual clock as the original clock widget when it opened.
Upvote 0
BEST TECH IN 2023
Smartphones
