Help Dual Micro Sim Adapter for s3 ?
martytarty
Member
I have 2 contracts with o2, I have my new gs3 plus my old gs2.
I'm going to sell my gs2 but still have a sim with mins,text and data, will either have to cut sim down to micro size or request a new one from my network.
I'm looking for a dual swim adapter but I can't seem to find any for the s3
Also the S3 takes micro sim so is it even possible for a dual micro sim adapter?
not sure i follow 100% but if your s2 has a full size sim you wont be able to interchange it between that and your s3 unless u cut it down and have an adapter to adapt the micro size sim to your s2 when its not in the s3!
Here you go MicroSim Adapter 3FF mini-UICC Shop
I got 5 in the mail today.
What do you mean you don't follow 100%?
I'm keeping my s3 that takes micro sim, If you read my original post I did say that Im going to need to cut down the sim in my s2 or order a new micro sim
So the scenario is, I have a galaxy s3 but I want to use 2 micro sims with it, so I'm looking for an adapter that allows me to have 2 micro sims in my gs3 meaning I don't have to keep swapping sim cards
i dont think they have anything like that for the s3 but good luck in your search!
I'm also looking for this, has anyone found any dual sim adapter that works with the Galaxy S3?
I have been informed that magic-sim.com are about to release one for the S3 that is micro sim in size. I expect it'll be something like the one that is already available for the iphone 4 with on micro sim slot and another full size sim slot.
Hope this helps.
If you have come across one already, I'd be grateful if you'd let me know of it.
Thanks,
John
Hope this helps.
Thanks,
John
Is this what you guys are looking for?
Dual SimCard Adapter for Samsung Galaxy S3 SIII I9300, Gu Su Xin Chen Electronic Corp. Ltd
also on ebay:
Genuine Dual Sim Card Sims Adapter Holder for Samsung Galaxy S3 I9300 Microsim | eBay
Also, could you please explain for a noob how something like this would be implemented? How do you set it up on the phone?
Thanks!
