Help Dual Sim Data Connection Problem
  • Start date Start date
A
Android Question
Guest
I have a Samsung Galaxy Grand Neo, a dual sim running 4.2.2
My sim cards: #1 Vodafone and #2 Sim card from my internet USB stick
With my old phone that had 2.3.4 my second sim worked smoothly since i only had to activate data transfer for it after i set it to be the 3G Sim.
With this 4.2.2 this seems impossible. It seems to be based around the signal0 of a provider since for my Vodafone sim he detected the Vodafone system. For my other sim it's impossible since his main antenna doesn't emit any GSM signal to be recognized by this 4.2.2 that seems to be fixated around the idea of a GSM signal.
My Vodafone sim has 25 Mb of internet and at first, he also wasn't able to use them. After some pure random luck and restarts, it seemed to work, but i can't make it work it again.
I tried any logical solution and setting in the 4.2.2's quite limited menu regarding this option. I switched the sim's places. Nothing. Logically, i think, i need only to select the 2nd sim while having data transfer enabled but this doesn't work.
If you have any idea how to fix it, i will appreciate it greatly! Thank you.
