Dual-Sim Question
Hey guys, I'm thinking about buying a dual sim android phone. I wanted to ask if you can use one sim for calling and texting and use the other for data and internet use.
Which device(s) are you considering?
I'm not aware of any dual SIM solution that allows you to use both SIM's at the same time.
Have you verified that that carrier you're intending to use for data only will sell you data only?
Yeah, I ordered a hero h2000 phone made in china. It's a dual sim phone with android 2.2
I dunno, if there is a plan for data only, but I was planning on using a sim plan with unlimited data and few hundred minutes/texts. And use another sim for calling/texting.
