Help Dumb nandroid question
thecarlsoncrew
In the past, I've always used a bootstrapper app to boot directly into recovery mode in order to create a nandroid backup. Now that I'm on JB, the Razr Bootstrapper actually killed my phone, so that's no longer an option. I've tried booting into recovery mode in various ways (with TitaniumBackup, ROM Toolbox, ROM Manager, and manually) and can get into the "Android system recovery <3e>" menu with all of them...but there's no option for creating a nandroid backup in there. On ROM Manager it appears there's no supported CWM Recovery for the Razr yet, but it tells me that TWRP is installed and is trying to use that recovery instead (it doesn't work).
After I initiate the reboot sequence on TiBu and ROM Toolbox there's a brief error that Superuser has stopped before the screen goes dark, so I suspect that's related, but it was always there before when I used the bootstrapper apps (they worked anyway).
The point is...how does one reboot into a recovery that gives me an option to create a nandroid backup? I should probably be able to figure this one out, but am having a mental block.
Thanks in advance!
