electricpete
Android Expert
The available playstore update of Wear mini launcher from version 5.6.9. (to version 5.6.19 I think) is asking for additional permissions to SMS, phone and "mail" (whatever that is). I don't think there's any sane reason that a simple app drawer should need permission to my SMS or phone functions.
So I looked for a replacement and found apollo wear launcher ... it’s a nice free app that does roughly the same thing but without the permissions. A video is here:
Comparison:
Apollo has better gesture launch: First advantage: Wear Mini Laauncher gesture shortcut requires you to slide from the extreme left side of screen toward right.... but that's the exact same gesture that you need in many other contexts (like if you've swiped right on a notification and then want to swipe back left), so inevitably you will launch the wear mini launcher many times when you don't intend to. In contrast the Apollo wear launcher gesture shortcut is unique: it starts at lower left of screen and swipes diagonally up (first advantage..won't trigger that by accident). If you release the swipe in the middle of the screen, it launches the apollo quick settings. If you release the swipe at the upper right hand corner of the screen, it launches the apollo app launcher. So that’s a second advantage... one quick gesture from watchface to either quick settings or app launcher... dont' need two gestures to get to the quick settings like wear mini launcher (I like the ability to quickly tweak my brightness). You can of course launch either launcher from an app shortcut on your watchface (rather than gesture launch) if you use watchmaker or other face that allows that type of thing.
Wear Mini launcher has slightly better app launcher interferace on round watches: Both let you hide apps that you don’t use frequently (a great feature to unclutter the app drawer). As for bookmarked/frequently used apps, wear mini launchers places them at the beginning, Apollo mini launcher places them on a side panel… which is more elegant in some ways, but takes up space for scrolling through all apps. Apollo allows to set up my moto 360 2014 as either a round watch or square watch. If I pretend it’s a square watch, then as expected there are some things that don’t work well: 1 – the gesture launch feature doesn’t work; 2 – the bar for the frequently-used/bookmarked apps doesn’t work as well… tends to hide the app at the top of the list. If I tell Apollo the truth about my round watch, then it does some “clever” manipulations with the apps on the left side of the list during scrolling so they expand/contract to follow the watch's round countour (see the video). It’s a novel idea but a little bit distracting and makes it harder to find an app quickly… I’d actually prefer the simpler approach of wear launcher which also resembles what I get if I tell Apollo my watch is square. But assuming I tell the app that my watch is round (so I can use the gesture launch), then I’m forced to accept it. It’s tolerable when you select a width of two columns for the app drawer. But if I select three columns of apps, then I have to get rid of my side bookmarks bar on the right in order to make enough room to be able to see the apps on the left as I slide through.
So in summary, I’d say the gesture launch is better for Apollo. The drawer itself is slightly better for wear mini launcher (if you have a round watch... square watch not much difference). The tie breaker for me is the silly wear mini launcher permissions. Uninstalling.
btw if you're thinking about trying out Apollo, you don't have to uninstall Wear Mini Launcher to try out Apollo...they can peacefully coexist on the same watch. That's what I did... didn't uninstall Wear Mini launcher until I was sure I was switching to Apollo.
Comparison:
I was wondering what it was doing within the app.
