Dungeon Hunter 2 HD Screen size problem
Cookeeh
So I got Dungeon Hunters 2 and installed it on my Samsung GTi5500. But when I launch it the screen is too big and I can't continue due to this. Is there any way I can resize the resolution to suit my android? :confused:
the HD in DH2 means that the game runs at 800x480 or higher. since GTi5500 only run 320x240, it is unlikely that there is any change you can make to the game that will support your phone resolution. The best thing you can do right now is contact Gameloft support to see if they will give you a refund, or give you a credit for another game that support your phone resolutions.
Unfortunately, in today's smartphone standards, your phone is utterly outdated, and won't likely get any good games or game developer supports :(
I'm having a similar problem on the Motorla Atrix and I know damn well that the screen is plenty high of a resolution. All the displayed "buttons" are off (displaying too high in comparison to where you need to touch to activate them) by a good margin so none of the bottom "buttons" work.
When I go to gameloft.com and try to buy Dungeon Hunter 2 for the Motorola Atrix it says "Sorry, Dungeon Hunter 2 HD is not available for your phone at the moment".
So where did you get your copy?
If you have a rooted phone, the program LCD Density Changer may help solve your problem.
My problem isn't getting it to work. It works fine on my Galaxy Tab and on my Epic. I needed to redownload the game and it will tell me they are sending a text with the download url. I haven't got one yet. Or it tells me I haven't downloaded any games. Frustrating I sent them an email so we'll see
