There is dust under my X10 screen its pretty noticeable how would i clean it out , Should i try opening the X10 to clean it and is it hard to open the X10 and will it easily break
I would advise against opening the phone, I think you have to break something to get access to the screen but this is something I heard a little while ago, so maybe it's easy.
Unless you really know what you're doing, don't do it!
