Earphone Sound reduces to 0
Terry_P
I be listening to either Radio or music fine for a period of time with my earphones, when the volume just reduces by a couple of notches, then shortly after, reduces to zero. I increase the volume, but it again reduces to zero again. This happened before the kitkat firmware update as well.
If i remove the battery and restart it will work for several days before having the same issue again.
I should state these are cheaper earphones - Kitsound Ribbons In-Ear Earphones, but have had issues with another sort as well.
Suggestions?
