Ok, first off, I'm sorry if this method is already on here. I'll delete this post if it is.
info: Works on Windows 7 64-bit, Permanent (but can unroot), No messing with the kernal or ROMs, One-click, easy, and it's badass.
1.Disable pdanet, easy-tether on PC and phone, as well as any other apps running (run advanced task killer).
2.Grab these files: InterceptFroyoRoot v0.2.rar and unzip them in one folder.
3.Make sure you have the drivers and that USB debugging is on and the PC can recognize your phone. (duh)
3.Run START_ROOT.bat. Follow the commands, the exploit will run. This took two times to work for me, and my phone did not automatically restart. At first attempt, it gave me "read only" access errors. When it finally worked, the batch program hung after it successfully completed with no errors at the "press any key" to restart phone prompt. I manually restarted, and I have root access and it was verified with Root Check app.
4. That's it. Props to kuroyoma at sdx developers and this thread: One Click Root And Unroot For Froyo Intercept For Windows (Updated)
If you want to unroot, run START_UNROOT.bat
I have successfully deleted the Amazon mp3, Where, Google Chat, Facebook, and AirChat without any adverse effects via Titanium Backup Pro
The only strange thing is that superuser is just granting root access without prompting me to allow or not. Meh, though, I dgaf.
btw, Use at your own risk
