How To Easiest way to convert Vidoes
I'll give it a try. I was trying to convert videos a while ago, when i took about 30 videos of my friends on a terrain park while skiing, with my droid. it took FOREVER
Well I meant it more for converting videos to watch on your droid, so for your application I don't know that it is as useful.
ROTF what?
You set your settings *once* and make it a profile - then you convert using same profile - 2 click process, 1) select profile, 2) select file, 3) off you go.
If this is a contest in easyness, DoubleTwist would win.
Recognizes your android when you plug it in, drag file to your phone icon, done.
It converts and stores in your video folder.
I guess you could say that it's the easiest but why do I need a full blown sync application when I can just drag and drop myself? I haven't ever tried DoubleTwist so I'm going to go ahead and download it and give it a check before I dog on it too much.
Have to admit I havn't tried your method either so it might be faster or more efficient, I don't know.
Just saying that DoubleTwist will probably get the least clicks out of the process, if easyness is your main goal :)
I couldn't for the life of me get it to convert it and put it on my droid. Maybe I'm too impatient but it doesn't even say a percentage anywhere when it says syncing to droid.
Converting an MKV took very long for me too but converting an avi was a pretty normal conversion time.
Like handbrake, which I use the most (smaller filesize, still 4gb card)
