redesignni
As topic says... anyone know the easiest way to remove the screen protector thats on the device when its unpacked? Ive scored it and want to put on a new one.
Cheers
Robert
Cheers
Robert
Just use your finger nail and peel it up from the top corner, or you can use something like a toothpick, the screen it self is supposed to be scratch proof so you will be ok, it peels of fairly easy, and then just make sure the screen is spotless to put on a new one.
So there is two screen protectors? One thats already on when you buy it, and then another one in the box that you have to put on your self?
So we would be safe without any screen protector at all, im on my second one and the screen protectors are 9 euro a pop!!!!![]()
The screen is made of mineral glass, so it's naturally scratch resistant. If you prefer to have the extra coverage of a protector (as I do), go with something like Clear-Coat, as they provide a lifetime guarantee.
I presume they ship internationally???
i just removed my screen protector, not sure if its better without it or not... still getting a lot of fingerprint marks on it when i use it....
