Root Easiest way to root help
Craiggers
so far ive tried an apk file for rooting, one click root and nothing has worked. any ideas.
all help appreciated. do u need to know which firmware version i have r nything
tried that apk mate. didnt work. if i try and run root explorer ir says i dont have superuser yet and crashes. any ideas
The apk should work on 1.6, it's tried and tested. If 2.1 the only way at the moment is with the SuperOneClick program that runs on the PC.
still on 1.6 btw.
when i run the apk u said about and click root it completes and says to restart system and i do and then i switch back on and if i click on x10 root app it says root and other options are grayed out. ny ideas.
not having much luck pal haha
still on 1.6 btw.
Not a clue, never had any issues with it at all. What firmware do you have?
Should work fine then. Try installing SuperUser first (from Market) and try again. Like I said, it's tried and tested and never had any issues with it myself.
All I can suggest is that you have a read of this thread - Exploid One Click .apk Root - to see if anyone else has had the same issues.
oh dont worry followed the quick update way on xda forums by changing the numbers in the default file. its downloading now pal. appreciate all ur help. will post when complete
its installed and running and all now mate. cheers for help. is it worth rooting it?
Nice 1! I think it's worth as I like to mod my phone and remove the Moxier crap along with a few other apps, plus as you've figured some apps require you to have a rooted phone, so it's your choice if you want to or not.
