Not sure if anyone has not tried this but to save on fingernail ware and tare (literally in some cases) here is my tip.
Use a coin. just place the edge under the lip that you would normally place your fingernail supply a little force to slide the batter down a bit then useing the coin as a lever pop that battery out.
Hope this helps.
And sorry if others have pointed this out.
Oh, keys work too, but coins should be safer due to rounded edges.
Hope this helps.
