Easy explorer
Easy explorer will allow you to find your file on the memory card for the least amount of time. Forget about a bunch of directories in the card. Put your file in any directory, run the application and select a group, such as music, documents, video, and the program will show all the files to the selected content. Program in color separates programs from different directories, and can be filtered by the name. The same file can be started by touching the screen.
The program can display images in Explorer
The program can play music in Explorer
You can select to play music only in a specific directory.
Market
