Easy Picture Hanger [Tools]
aea
Hello Everyone, I've recently released an app in the Android Market called, "Easy Picture Hanger". This app enables you to quickly and easily find locate the optimal location to hang a picture, while calculating where the hook should be placed on the wall.
Features include
  • Supports Centimetres and Inches
  • Allows "real world" input for Inches using fractions (ie, 24 3/4)
  • Will show a simple diagram with measurements
  • For inches, the calculated displays will use fractions as well
  • Configure the optimal height (if you want to hang picture higher or lower)
  • Simple built in help that hopefully answers any questions you might have on how to use the app
This is a paid only application. There are few reasons for this, but primarily, it's so that I could release an App without ANY special permissions. I could have released an Ad supported app, but to be honest, for 99 cents, hopefully this app will provide value to some people.
Here are a couple screen shots taken from the Android Market
hO54NZs8qUCU-1nuF3Y4xs6lNkf8pA5z8srSUt3piXi_68y8Q2vWbAzvDSAAeckTng=h230
mqu9dAR9VIol8P0k0r-NS9ZruFozdGPeJb9XhBISdNoZVk-wMzrba_B_Sw17Bu8e3g=h230
I appreciate your feedback and support.
Thank You,
Sean Stuckless
Android Easy Apps
(Android Easy Apps)
