Easy Silencer - Ringer volume management app
coplas
Hello,
I'd like to present you my (recently updated) app:
Easy Silencer is an Android application directed to getting control over the volume of a telephone ringing. Its functionality can be divided into two parts - automatic volume setting up and quick turning down for a certain time.
YouTube Video:
EasySilencer - YouTube
Automatic volume setting
Automatic volume setting enables simple volume setting for chosen hours, it is done
very easily and innovatively - just "draw" on the screen maximum volume during a day. No complicated settings are required! It is also possible to have profiles for different days of week.
Rapid turning down of the ringing for a given time
To avoid necessity to turn on ringing, e.g. after movies showing, Easy Silencer provides just to turn down the telephone ringer for a certain time. Later the ringing volume returns to the original volume. The telephone does not remain in a silent regime by mistake when you do not wish it. For simplification the application contains widgets with the possibility of rapid turning down.
Also the integration with the popular Dash Clock Widget is available.
The application is in Google Play Store for free.
Google Play Store:
https://play.google.com/store/apps/details?id=com.easysilencer
Web:
Easy Silencer
Hi there!
I've moved your thread to a more appropriate forum... App & Game Announcements. ;)
Have a great week!
