Help Easy Tether Help!
TokedUp
I need to tether my laptop to my DInc, I d'l the app Easy Tether and installed the driver on my cpu but it says "Connection Failed enable Easy Tether Driver in Connection Settings" or something along those lines. can someone please help me.
Also whats the diff between the 32 and 64 bit drivers for cpu?
Nevermind, I d'l PDAnet and it worked right away! no probs at all.
If you're not sure whether you need 32 bit or 64 bit drivers, you need 32 bit.
You shouldn't have even been able to install 64 bit unless you have a 64 bit OS, so I doubt that is the problem.
What operating system is your laptop using?
