Root Easy way to flash recovery.img
DjSidEShoW
I don't know if this will help the development of cwm for our device by allowing us to re-flash the stock Recovery after flashing a non working recovery. Or, maybe its an easy way to flash any recovery that we might want to test.
Its an app called "Recovery Installer". It allows you flash a recovery.img from your phone. No computer needed. Just re-name the image "recovery.img", place it in the root directory of your sd card and press flash
Check it out and let me know if this will help.
Coild you possably link the app or post apk ?c:
I forgot about this post, whoops!
I actually tried the app and it didn't work for me. But feel free to try it(or another app just like it, there's a few). Just go to play store and search "recovery flasher".
And if you find one that works for you let me know because it sounds a lot easier than the adb method or the terminal emulator Method.
It works ! Recovery flasher utility is the app that worked got touch recovery working
That's the exact app I tried using and it won't work for me. the app tells me that the recovery Is flashed but when I boot into recovery, no change.
I'm glad it works for you though. But as for me it looks like I will be using my terminal emulator. No biggie :)
Same it would say it flashed but really doesn't. lol
