Easy tether pro...actually had problems with foxfi.
Hi, I have easytether pro and it used to work flawlessly. However, after the ics update, it doesn't work. I connect my phone and it recognized my drives. However, Easytether on my computer doesn't appear to find my phone to connect. Can you please explain how to make this works.
And that's the name of that tune!Is EasyTether compatible with Froyo (Android 2.2), Gingerbread (Android 2.3), Honeycomb (Android 3.x) or Ice Cream Sandwich (Android 4.x)
Absolutely yes, EasyTether is fully compatible with these Android versions.
There is no need to use easy tether or any other wired tether app. Verizon only charges for wireless tethering. USB tethering is available without rooting and without charge from verizon.
To get it to work you must first tether your phone to a computer and then select usb tethering from the settings menu. It takes a minute or so to conect and then your good to go.
Problems? Please explain ....... I had none.
does this work on a mac?
any completely wire free tethering options on 4.0.4? ive been reading alot of conflicting info
