gonzalom91
I bought Easytether to go around virizons limited data usage. when i tried running the setup wizard in my compuer i got an error massage. "setup ended primaturely", and does not let me finish the instalation. I went to the easy tether F.A.Q and they say this:
If you use Windows XP, open Control Panel → System → Hardware tab → Driver Signing and verify the "Warn - Prompt me each time to choose an actions" check is set. If it is set as suggested or you have Windows 7/Vista, try to disable temporarily any third-party applications that may prevent the installation of non-WHQL drivers.
I tried searching google for more info and got nothing, im new to this site so i cant post pics of the erro massage. please help
