Eclipse and Android SDK emulating problem
moisoiu
Hello guys, i can't emulate anything on eclipse. I followed the other topics here on the forum, but no succes (i tried to install the Android SDK in a special folder like C:\Android\Android-SDK\ but still no succes). Each time i try to run the simple aplication which say Hello Android it give's me only ANDROID.
I putted some screen-shot with this maybe you guys can guide me.
I have to mention that i had 1 problem at the beginning when i was trying to install Android SDK, the aplication told me i didn't have installed java sdk (so i installed java sdk but still it told me that i didn't had installed, so i just copied java.exe from program files x86\java\java.exe -> to -> windows\system32\java.exe) and after that worked installing android sdk.
I have windows 7 enterprise x64.
I hope you guys can guide me. Thank you
