Eclipse, Form Widgets wont be dropped in Graphical Layout
jakmanne
Hey
I recently bought the book "android development for dummies". One of the first "tasks" was to drop some widgets from the "Form widgets" into my main.xml file.
When I drag "checkbox" or "button" into my main.xml file viewed in Graphical Layout this error appears:
[I118N] Hardcoded string "Checkbox", should use @string resource.
But when i drag "rating bar" over to the main.xml file, it works fine.
So do you guys know how to fix this?
Thx for help.
