Hi everyone,
I recently got a Samsung Galaxy Tab from work to do some development on. When I connected it to my computer the driver succesfully installed but when I open up Eclipse (Galileo), the IDE doesn't recognize the device. I can't find it in the DDMS perspective and when I run the app the device doesn't show as an option to push to.
I wasn't sure if because this was an AT&T device that for some reason I couldn't use it (not sure why). I was looking around and I found this site:
Samsung Mobile Innovator - Samsung Developer program for Windows Mobile and Java
I'm not sure if it's necessary to actually use the galaxy tab or not but I've been trying to set it up too and it's failing. Whenever I add http://innovator.samsungmobile.com/android/repository/srepository.xml
as an add-on site if you expand the user add-ons category it says it failed to validated the xml for the repository at that url...
So since I'm working on a work computer I have limited access to uninstalling and reinstalling things. I was wondering if anyone knew of a solution.
I'd really appreciate any help
