V vasilios tsakanikas Lurker Apr 25, 2016 #1 i just got a CUBOT H2 android phone and its stuck on edge network and i cannot change it . any suggestions please. thanks
The_Chief Accept no imitations! VIP Member Apr 25, 2016 #2 Go to Settings --> Wireless & Networks --> More -->Cellular Network Settings and check your settings in "System Select" and "Network Operators".
V vasilios tsakanikas Lurker Apr 25, 2016 #3 The_Chief said: Go to Settings --> Wireless & Networks --> More -->Cellular Network Settings and check your settings in "System Select" and "Network Operators". Click to expand... thanks i tried this and nothing happened.
The_Chief Accept no imitations! VIP Member Apr 26, 2016 #4 I would then suggest you consult your cell provider for assistance
P Parayilhussain Android Enthusiast Apr 26, 2016 #5 Settings>more>mobile networks> Data roaming>enable .
