If you are using Handcent SMS, then you can change this setting. Go into Handcent, then Settings->Application settings->Action key type. From there the choices are either enter or smile. This will change the '' to the enter button.
I am not sure how you do this if you don't have Handcent SMS, maybe there is a hidden setting outside of Handcent, maybe in the stock messaging app? Either way, I hope I was able to help you out!
