Hello guys
I need your help, i'm working on a mod and a friend said me to modify the file: settings.db located in data/data/com.android.providers.settings/databases/settings.db
I only have to change "1" to "0" in the "secure" tab
for this I used Sql Lite browser for windows 7.
So i did it and saved the database, and then with root explorer replaced with the original settings.db but ....
I entered in a boot loop, why ?
I know for sure the "0" is a secure value, because used in a stock old rom
Why bootloop so? Have I to changed permissions to file?
This is probably the right way, i didn't change the permissions to edited file like that of original file.
Thanks
Thanks
