dimension11
I have a N9005 which has the stock Samsung ROM, the only modification made is that it's rooted with the Odin method.
I edited the build.prop file, and the system is stuck in a bootloop (just blank screen after the animated Samsung Logo).
I made a backup of the build.prop file on the extSdCard.
What's the best way to get the phone recovered? (hopefully without doing a factory reset).
I tried using ADB but it doesn't recognise the phone (even with Samsung Drivers installed). When I boot into recovery mode the options are:
1) Reboot System Now
2) Apply Update from ADB
3) Apply Update from External Storage
4) Wipe Data/Factory Reset
5) Wipe Cache Partition
6) Apply Update from Cache
