Root Edited D4 build.prop (Help!)
PKR
So I replaced my build.prop with a preassembled one I found over on xda. Now my D4 won't boot past the Dual Core screen. I've tried reseting to factory default but that doesn't seem to work as it only edits the /data folder. Is there any way I can get to the /system folder in order to replace my build.prop?
I don't think so. You'll probably have to flash a fastboot file. Which build.prop did you use, by chance?
