Apps Editing TextView from EditText on Button click
Hey guys, new to the forum :)
I had a question on a piece of my code..
What I'm trying to do is learn how to set a TextView's default text to whatever I edit in the EditText
In Lamence terms..
Default Text <---Label
[Default Text] <---Text Box
[Change] <---Button
If I change the information in the Text Box, it will change the Label on the Change Button click..
Now, it will change the text to 'false' and I can't figure out what I'm doing wrong..
Here's my Main.java:
Code:
package com.testapp.android;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
public class Main extends Activity {
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        changeButton = (Button)findViewById(R.id.change);
        changeButton.setOnClickListener(new OnClickListener()
        	@Override
        	public void onClick(View v)
        		changeLabel = (TextView)findViewById(R.id.label);
        		changeLabel.setText(R.id.textField);
    public Button changeButton;
    public TextView changeLabel;
and here's my main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent"
<TextView
	android:id="@+id/label"
    android:layout_height="wrap_content"
    android:text="Default"
<EditText
	android:id="@+id/textField"
	android:text="Default"/>
<Button
	android:id="@+id/change"
	android:layout_width="wrap_content"
	android:text="Change"/>
</LinearLayout>
Thanks a bunch guys :) If you have any questions on what I'm trying to do feel free to question, I know it's kinda hard to understand with my ASCII drawing :p..
