[Education/Tools] AppNomadic Flashcards
A flashcard app that allows you to create flashcards in any language (supports unicode). Cards are organized into decks and their is a folder system to aid in organization. Packs are a playlist for decks and can be used to generate a multiple choice test with results to show which decks you should focus on. Studying is weighted and random based on how many times you hit the check on each card. Cards will stop showing up in a study after being checked enough times, until all cards have passed.
Check it out at https://play.google.com/store/apps/details?id=com.appnomadic.mobileflashcards
Feel free to leave any suggestions or feedback. Thanks!
ufBBxweGUQNq6hQlzB1dOIQ8psgmdKuSxO7zLMluo3KZSCIeNvyreYqEsH-zyoot=h900
