EDUP 150Mbps 802.11n Wireless LAN USB Mini Adapter
Bought this adapter for 1.35 +6 bucks shipping
works awesome
internet is about 3X faster, and the range works everywhere in my house now.
i totally recommend it.
didn't have to do anything. just plugged it in and it worked
1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220754808008&ssPageName=STRK:MEWNX:IT
As a bonus no more speaker pop
Wow!
Thanx man for that very useful info buddy! ;)
You are doing wonders!
Hmm I tried to add a SURECOM Bluetooth which i think is Toshiba Tech under the hood to my Upad... sadly it had no response.
Has anyone tried any other USB devices sucj as Bluetooth to the Upad?
I can confirm the SURECOM Bluetooth dongle does not work.
How do I mount it through terminal?
I am not too fimiliar with Android Commands :/
So hopefully some one can guide me through it even if it is possible?
Ok, so I need some help here, not sure what is exactly going on, but its not working on my Zenithink tablet. Can anyone help me? Thanks.
Same for me. I cant get it work with the USB lan adapter. Still unable to connect to WIFI network.
Anyone can help me please?
wifi wordked fine foe 3 days. now cannot connect at all. am getting that wifi is available but it wont connect. it shows wifi symbol with a question mark over it in notificationa area but no info in the notifications.
i have also tried to connect with the ethernet adapter supplied but no
luck at all. i am not sure what settings to put in for lan settings?
Hello,
I have rtl8188cu wifi adapter I want to connect it with my android because my android mobile wifi, Bluetooth and hotspot not working
