Help Eliminate Slide to Answer with Easy Answer
CTB6
Member
This info was buried in the "eliminate vibration on unlock" thread, so I thought I'd make it more obvious. I just tried the "Easy Answer" app, and it makes it so that you only have to tap a large button to answer a call, not slide. It seemed to work ok on mine, so as long as this continues, I'll be keeping this one.
Thanks to user monmur for this information!
I read that thead but hadn't noticed it. I installed the app and it works great so far.
Now we need to find an End Call button which is more critical for me. I have 7 more days to decide if I want to keep this phone. Finding an end call button would mean I definitely keep this phone. How could Samsung have been so stupid?
I'm with you on that one, Winner. The answer slide was a minor annoyance; the end call is going to make me drop kick this thing some day. Hoping for a solution to this.
