email and calendar question
donas
Is there a way to use the stock email app. for hotmail and have it not delete emails from the server?
How about changing the color of the font in the stock calendar?
Thanks
update-- I figured out to select "manual" setup and choose "pop" there is an option here to select not to delete from the server.
If you check your Hotmail account on the web, you should see a sub folder that says POP and should have all of the e-mail deleted from your phone
