Every time I try to send an email thru Yahoo on my Kindle Fire HD, if I make an error and try to backspace it deletes my whole email. Any suggestions? Right now I want to chuck it out the window!
I have been using the delete key. Are you saying yahoo should work? I guess I'm not as computer literate as I thought (which wasn't much). What is the default email application?When you say "backspace", do you mean to say that you use the delete key? Or do you use the back arrow on the bottom of the screen? It sounds like a silly question, but you don't know how many times I have used that back arrow by mistake!
I would advise that you use the default email application. It appears to me that the default app is compatible with Yahoo! mail. I use the default app for all of my email needs, and I never have a problem with creating email.
Good luck! And post again if you need anything.
