D
danimasterson89
Guest
I have the LG stylo 3. I keep accidentally calling 911. It's happened 4 times in the last year or so. How do I stop this from happening? It usually happens when my phone is in my pocket and locked.
Sign up with a carrier.
WiFi calling doesn't work without a carrier in the US. 911 always works. How?
But how?911 will always work, carrier or no carrier.
You can pull the SIM and lock the phone, and still call 911.
via wifi...thus the name wifi calling. the sim card is only for cellular and 4g. it does not inlcude wifi.But how?
But how?
Additionally, GPS is always enabled, regardless of connection status. So somebody can always tell where you are!It is mandated to work by law.
I dont think Wi-Fi has anything to do with it either.
The scenario can be that you are in an accident and someone helping only has your phone to use- and you are incapacitated.
This allows limited use of your device for emergency calls.
The dark sided opinion is that this means that your device is always able to connect- regardless of what precautions you take- so chalk up another one for the conspiracies about these things being tracking devices.
I don't think so. You can turn it off, but! Somebody may notice.Additionally, GPS is always enabled, regardless of connection status. So somebody can always tell where you are!
I'll provide a link if you need one...
