Emulators Help
NABNAP
I searched around the forum but all the emulator posts are old from when there were still emulators on the Android Market. So, how do I install these? Which ones work well on the Galaxy S2? Many thanks.
Im using 114n64apk, i know theres newer but this works spot on on my GS2....
Then all you need are the rom's which can be found on the net.....
HTML:
https://slideme.org/en/user/3168/applications/3168
Should be easy enough for you, though some problems with the 64-emu.
