kemonine96
Member
Tethering
Thanks to nicedream06 for figuring out how to get tethering on the stock ROM without the need for an ATT tethering plan. I have taken his work and turned it into a simple update.zip and Tasker profile. You need root in order to do enable tethering.
Enable Tethering
Stock Tethering
Enable Tethering
- Download enable_tethering.zip
- Drop it onto your sd card
- Install from Clockwork Recovery
If you do not have clockwork recovery, but have root, unzip the package and read through the update-script. - Reboot
- Install Enable_Tethering.apk if you don't have Tasker. The app was generated from the below profile using "Tasker App Factory".
- Install Tasker
- Download Tasker_Enable_Tethering.prf.xml
- Drop it on to your sd card
- Import the profile into Tasker
For the curious: It runs sqlite3 every time the mobile network becomes the primary internet connection ensuring that tethering will allowed. - Enable tethering!
Stock Tethering
- Download stock_tethering.zip
- Your back to stock!
