Root Enable toggles for stock jellybean
TrustME90
Requirements:
Xposed framework
http://dl-xda.xposed.info/modules/de.robv.android.xposed.installer_v33_36570c.apk
Resflux xposed module
http://dl-xda.xposed.info/modules/com.iwisdomsky.resflux_v1_59427b.apk
1.open resflux and select laboratory
2.scroll to systemui.apk and select it
3. Select boolean (be patient)
4. You should see config_powercontrol_display.. change value to true
5. Hit done and reboot your force!
6. Enjoy!
Tip: you can also change the value for the toggle name/label under boolean config_powercontrol_item_text
Thanks to: rovo89 & tungstwenty for xposed framework, wisdomsky for resflux
Works for me but I have to use an older version of resflux because the newest version available right now crashes when trying to modify stuff.
