Help Enable Vibrate on Power off
nitansh
Hello
I am having a MICROMAX Q417 model.
There is a problem with my device :
"It do not vibrate after power off,
There is no sound during power on"
Please someone help me
"Please give solution that do not requires root (Is there any)"
Do the vibrator and speaker work normally when the phone is on?
Check your phone's sound profile to see if you have disabled the vibrator.
Yes sir
Reset of setting are normal.
It vibrates during incoming call and notification etc.
U can have a look on all setting in attached screenshot.
It do no vibrates only after power off (which is a feature of all smart phone)
So back to the original question, what makes you think that your phone must vibrate while powering off and makes a sound while powering on?
Just make test with my Lenovo K3 Note, it does vibrate while powering off but it doesn't make any sound while powering on.
As I am usng 3 other smart phones of same company MICROMAX and even my friens are using diffrent company smartphones like MOTO,Lenovo,etc.
These all phone vibrates after power off which shows that complete power off process is completed.
But my phone dont vibrates even after 5 min of power off
Another test with my LG G4 Stylus, it makes sound while powering off and on but it doesn't vibrate.
So I think your phone is perfectly fine, different firmware versions can give the phone different features.
Ohk sir Thank you very much
thanx for giving attention and your precious time to my problem
  • Like
Reactions: lvt
