Enable WiFi Tethering
sr10638
This will require root access on your device, if you don't have root yet see my other post on how to enable it.
Even after enabling root on this device all of the tether apps state "hotspot is not supported" when starting up tethering. I guess Samsung or Virgin really locked this one down. I finally got around this by following the guide on this link How to Wifi Tether ANY Rooted Android Smartphone or Tablet! [Universal Guide] | HighOnAndroid.com. It works and I have had no issues yet with it.
The guide in the link above will give you step by step instructions but I will list them here for you too.
1) On your device download and install the Wifi Tether TrevE Mod APK Download apk/wifitether/treve/wifi_tether_v3_3-pre2.apk at DownloadAndroidROM.com Install using the package installer and not the Google installer. (Again you must have installation from unknown sources enables in security)
2) Launch the app Wifi Tether TrevE Mod and make the following chnages to the settings.
3) Press on “Change Device-Profile”, select “Generic ICS/JB (wlan0)”.
4) Choose “Change Setup-Method”, select “Netd-Ndc (master)”.
5) Make sure “Send Netd Max Client Cmd” is checked.
6) Make sure either “WiFi-driver reload” or “WiFi-driver reload 2″ is checked on. If wifi tether fails for some reason you can change this to the one you didn’t use.
7) Scroll down and make sure “MSS clamping” and “Routing fix” are both checked on.
That's it! Remember you can set your wifi encryption and SSID in the settings to whatever you’d like.
Go back and click on the yellow WiFi symbol and test out the connection.
Again I just found the resource, all credit goes to XDA and the page How to Wifi Tether ANY Rooted Android Smartphone or Tablet! [Universal Guide] | HighOnAndroid.com for making this happen.
Let me know how it goes for you!
-SR10638
Hey sr10638 Just wanna Say YOU ARE DA MAN BRO! FOR FINDING THIS MAN. ITS BEEN KILLIN ME! Not being able to turn this pain in the Behind phone into a hotspot! But Dude! Your Directions were ON THE MONEY! WELL DONE FOR REAL! GLO! ;-) Thanks for the Precise Exact And For a Fact! Directions Brother. Another HUGE! THANKS GUYS! Goes out to the EVERYONE AT XDA Who figured this WiFi Tethering Dilema Out And Brought Us The Awsome and Simple Wifi Tether App. You Guys Kick Arse! It Worked Easily and Flawlessly! GOOD STUFF GUYS! KEEP UP THE GREAT WORK! OVER THERE AT XDA! Thanx Again. This is AWSOME I'M STOKED! ;-)
