Help Enabling autosync for gmail on Droid 2
Ok, this is a very newbie question but I have no ideas lol. I have searched and can't seem to kind where I enable auto sync for gmail. If someone could please tell me I would be very appreciative.
Thanks
Nick
Just in case, go to menu - settings - accounts - google, and make sure you have email set to sync.
You can also add the power tools widget to a home screen and make sure you have auto sync set.
I've read that some users accidentally turned theirs off.
Hi,
So I got this same thing... I went to settings --> accounts, then the list of all the kinds of accounts i have are there... when I click on it, it won't let me configure it... either I can open it and then it's not in there, or I can delete it... where are the initial settings that I set like a while back when I first set this program up?
and how do I add the power tools to make sure that it syncs?
Sorry, I got my droid lil while ago and I am still new to this thing.
Hi,
The sync for gmail in in accounts. You'll see google, select it and it should show you what google features you have, usually gmail, calendar, and contacts.
To add the widget press and hold an empty space on one of your home screens, tap widgets and look for power control or something like that.
