energy management
cultor
Member
I was wondering, I added the widget to my home page and know 4 of 5 icons
I see bleutooth, wifi, brightness and synchronisation
But there is 1 more, what does that do? looks like a satelite icon or something....
Love that widget - The brightness one is cool too - just keep pressing it to see the 3 different settings. So simple to see whether your Wireless and Blutooth are on/off (Yes i do find it easier than looking at the tiny little icons at the top of the home screen), and a single press to toggle them - Great.
yep gps,
i use the htc ones under add widget>settings as they have the name of what they are underneith :)
only downside is there is no brightness one but then i dont alter that
yep gps,
I never used to alter the brightness, but at night it was quite surprising to me how much easier it is on the eyes when you knock it down a bit, and it takes just a press or two.
