Enigma v1.1 Theme
TheManWithAPlan
Slideshow of v1.0
My Theme Shotz - Web Album Created with Flash Slideshow Software
UPDATE
*Enigma V1.1*
Not much changes really, but basically
Updated the phonebook gui
Updated the command files a little
Updated package to include default theme incase anyone wants to revert
Also included my modified MusicGo
Updated timescape to allow people to switch themes without FC (hopefully)
http://db.tt/9o3bbsL - Enigma v1.1
*Note*
Just for reference sake im using a Rooted 026 x10i so not sure what happens with earlier versions of root such 020, 024, etc..
Also it is the early root methods and not the One Click Root so i cant say if it works properly for them or not.
the new adw causes the launcher to be out of place a little.. hence y ive still kept the last version (1.1.4)
The app modz steelclock and darkstar are for weather & toggle widget. may work for others but not completely sure!
*Extraz
Also a bunch of wallpapers ive quickly put together.. if anyone is interested -
http://db.tt/udBpJQE
*Warning*
Please use at your own risk.. dont want to be held responsible for anything that may go wrong. Thanx!!
that looks good....i will ask as many others will probably wonder but how do you install it?
I have this installed. There are three batch files included in the download. One for Apps, for System and one for the bootup animation. I chose not to change the bootup animation but I also had to edit the Apps batch file to fix a syntax error for the MusicGo app. I also had the previous version installed and had to add -r to each app line to force reinstallation.
I love this theme though.
thnx much appreciated
Do you mind if I get some help from you?
I'm trying to change the smiley icons that the x10 has right now to the default android ones. I have been able to pull the framework-res.apk off of my device and put in the new images. I have been following the steps listed at this site.
Step 1:
Connect phone to pc, enable usb debugging and open adb. Type:
adb pull /system/framework/framework-res.apk framework-res.apk
That will pull your framework-res.apk to whatever folder is displaying in your command line.
Step 2:
Find the framework-res.apk on your hard drive, right click and open with 7zip.
Step 3:
Use png's here or create your own and dump into the appropriate folder within framework-res.apk.
Step 4:
When you are done editing the files open up adb and type the following command:
adb shell mount -o remount,rw -t yaffs2 /dev/block/mtdblock2 /system
adb push framework-res.apk /sdcard/framework-res.apk
adb shell dd if=/sdcard/framework-res.apk of=/system/framework/framework-res.apk
I always fail out on step 4. I am able to push it back onto the device but I am unable to do
Code:
or
Code:
It always fails out and says something like "Unable to mount".
Can you offer any assistance? Thanks a ton. Your theme is great!
just a basic question first.. you havent mounted your phone via usb have u? just normal plugged in and ran command files?
if its not that im not too sure cuz if u seem to install my theme fine, i dont see why you should have any problems really. i mean you could just edit the framework file i gave you, open with something like winrar or similar, go to your pc folder where the icons reside.. then just drag the images from your pc folder into the folder within the zip file and just run the command file. should work..
try place the framework file itself within C:\
then download and save this command file to C:\
http://alturl.com/zi6ru
it should hopefully have done the job for you once it restarts the phone.
P.s - im sure the smileys in my set are android ones? :-s
I'm getting a 403 on your previous link. I have even created a drop box account and I still get the error.
hmmm not sure why that is.
try make a .cmd file with the following command within
I did what you stated and the operations still fail.
Here are the contents of my .cmd file:
Code:
pause
Attached are two pictures. One showing where my files are located, and the other showing the output of my commands. I think the problem is something with my root. I am rooted as I am able to run busybox and the such.
Figured it out! Turns out Superuser permissions app was blocking the su access even though the screen was turned off!
