penguinrepair
please post here only with bug fixes, logcats, and kmsg outputs
(PASTIES RECOMMENDED) thanx.
oh if the ultra jumps off the table and eats your ex pm me...
also note it took 3 bricks to create a decent kernel dont recommend this to anyone
i built the kernel specifically for bads3ctor's
CM7 for Samsung Transform Ultra(FOR DEVELOPERS AND TESTERS ONLY)
figured i'd make a place for other "devs" to post possible kernel fixes as to not confuse bads3ctor's cm7 post
well here it is:
bst kernel
PR_Alpha2 - BST
http://minus.com/mbQDTHqUM
spr kernel
PR_Alpha1 - SPR
http://min.us/mkMxmfJf1
a bow:
thanks to:
bads3ctor(for the willingness to try something new),
ShabbyPenguin(putting up with me),
requisite0(mkboot),
dodgejcr(getting me started),
bobzhome(for having sources uploaded)
samsung(for sending me the wrong fone after a long wait)
and anyone else that helped(you know who you are)
i built using the eabi 4.6 arm compiler and sources found @ opensource.samsung.com
i also incorporates a rooted ramdisk thanks to the zurgroot
more modifications to come as soon as i get time, have fun, i know i did building it
you are welcome to check the sorces i've forked to:
https://github.com/penguinrepair/Samsung_SPH-M930_kernel.git
from bobzhome's initial upload
alas: enjoy
as with all my others(the blue pill) unfortunately alot of work and requires windoze:
http://androidforums.com/transform-...tock-samsung-transform-ultra.html#post4090294
some old buildnotes:
http://forum.sdx-developers.com/?topic=19377.0
well here it is:
bst kernel
PR_Alpha2 - BST
spr kernel
PR_Alpha1 - SPR
a bow:
thanks to:
requisite0(mkboot),
alas: enjoy
