Hello,
I've been trying to figure out this problem all afternoon via Google and have ended up on this site several times, however I can't seem to find the solution to my problem so I thought I would just ask.
My work email is through Entourage (POP3 server it appears) and I am trying to set it up on my Moto Droid so I can receive and send emails from my phone when I am out of the office. I have Gmail for my personal email and since day 1 I have never had any problems getting that email to work on my Droid but I would prefer to keep my work and personal emails separate.
I set up it manually, and when it checks the incoming/outgoing servers at setup things appear to be working fine - I seem to be receiving emails no problem, but when I go to reply or send the message gets moved to my Outbox and just sits there. When I click "send outgoing messages" it appears to be working but then it gives a "connection error."
I've come across several threads and articles with others having this issue but none of the solutions seem to work.
I've double checked all the info from how it's setup here on my desktop in the Entourage program - here's my settings:
Incoming
Username: xxxxx@companyname.com
Password: xxxxx
POP3 Server: mail.companyname.com
Port: 995
Security Type: SSL (accept all certificates)
Delete Mail from Server: Never
Outgoing
SMTP server: smtp.comcast.net
Port: 25 (587 seems to work too)
Security Type: None
Require Sign-in box is left unchecked.
Now I tried checking the Required Sign-In box and entered in my username and password, however it tells me that that is incorrect and it cannot authorize, however when I leave the box unchecked, it checks the outgoing server settings and doesn't report any errors... On my work computer, the smtp server and port number all that's required, as there doesn't appear to be a username/password that is used for the outgoing server.
I'm at a loss for how to fix this - I've tried deleting it and redoing it all several times with no luck. I don't have WiFi setup on my Droid so there wouldn't be a problem with that...
I also tried that K-9 app and it gives me the same problem - everything appears to work but it won't let me send any emails out - just gives me a connection error.
Suggestions on what to do??
Incoming
Password: xxxxx
Port: 995
Outgoing
Security Type: None
