Does it have google talk voice and video?
Yes, but I haven't been able to try it with anyone yet to confirm it works.
I have 2 questions regarding this new leak.
1 Is a wipe reset required to install this or can you flash and still have your current files and settings.
2 is this leak pre-rooted? If not, is there a way to root it?
Everything about this leak has been covered except these 2 things.
Thanks....
I haven't found time to flash it yet, but it sounds like the radios (4g/3g service) has been improved.
Since it's not an officially released build and is still considered "in testing" I would likely void your warranty.
A few things I have noticed so far...(running the debloated leak)
Pros:
-Better battery life
-Smoother, no jittering like on the official stock 2.2
Cons:
-Streaming music is a problem. I have only tested Pandora, but it cuts off, halfway through a song. Google music streams fine with no cut offs.
-Ambient light sensor seems to not function, I have to keep my brightness all of the way up for when i go outside.
Other than that I haven't checked GPS functionality at all. Seems to be very close to final.
Im running the leaked gingerbread..i love my phone now.. Really fast.. Less frequent force closed apps.. Especially when i ran the spb 3d shell.. Runs smooth now..honestly.. I don't have any issues.. Ran quadrant scores up to 1500.. Using pro launcher .. I highly recommend this root setup
